Discussion topic: Sky satellite signal strength and quality
Message posted on 19 Apr 2025 03:10 PM
Sky Q box has been working fine but today the picture across all channels has been very disrupted - visuals dropping, and then getting the blue no satellite signal error screen, and the black no signal screen.
Checking the Settings > Status and the satellite signal is mostly showing locked but occasionally showing unlocked, the signal strength is fluctuating between 40 to 0 and and the signal quality is fluctuating between 50 and 0.
The connections to the Q box are secure and it hasn't been moved.. The dish hasn't been disturbed, and isn't blocked by any nearby trees.
The weather conditions outside are sunny but moderately windy.
Any suggestions?
Message posted on 19 Apr 2025 03:15 PM
Re: Sky satellite signal strength and quality
@41175
If you’re seeing a “no satellite signal” message check that the connections from the Sky dish going into the back of your Sky Q box are still finger tight. Otherwise it’s very likely a dish misalignment or possibly a failing LNB (on the arm of the dish) so check the troubleshooting on this link
It’s worth noting that:
