Discussion topic: SKY Q HDR Quality + Box upgrade
This message was authored by Leepeugeot This message was authored by: Leepeugeot
Afternoon
I have a SKY Q box around 3 years old and have just upgraded to a new Phillips 908 (MLA Screen).
I have 3 questions
Why is the HDR picture so grainey?
Have Sky got a new Sky Q Box that is better than mine?
Do they come out for free to re route my dish cable if requested?
The TV i have is amazing but the picture quality from the box is not
This message was authored by PandJ2020 This message was authored by: PandJ2020
Re: SKY Q HDR Quality + Box upgrade
Without knowing the model number we can't say...  https://www.sky.com/help/articles/sky-software-updates
But if you have a HDR capable box then it's the 'latest'.
They are likely to charge for that.
This message was authored by Padam_Padam This message was authored by: Padam_Padam
@Leepeugeot wrote:
Afternoon
I have 3 questions
Your TV is using technology which is much newer than Sky Q.
Sky Q's UHD HDR uses the HLG format which isn't the best. Sky content is usually more compressed than a lot of streamed content for example, and can therefore look a bit posterised/grainy.
Don't use any of the apps on the Q box - you will get vastly superior UHD HDR quality from the TV's own apps which will give you Dolby Vision and HDR10+ where available. Sky Q's apps can output HDR10 at best.
Leepeugeot
Would it be better if I had Sky Stream? Do you think they will bring out a new more uptodate box?
This message was authored by ThePope27 This message was authored by: ThePope27
@Leepeugeot,
I have used both Sky Q at my house and Sky stream at my moms house, and I can say that HDR looks so much crisper on stream than on Q,
________________________________________________________________________________________
Sky Q 2TB v2 Box + 2 Mini Boxes - Brsk BetterNet1000 FTTP, WatchGuard M400 Firewall, Plume Mesh
Sky Signature + Ultimate TV Pack, Sky Sports, Sky Cinema, Sky Kids, TNT Sports, MUTV, LFCTV, Racing TV, Premier Sports, DAZN
Sky Stream does have newer and better video processing than Sky Q but has its own issues and limitations, particularly if you like the ability to record and fast forward/rewind easily.
There will not be an updated Sky Q box in the future. It is obsolete tech, designed & released under the old Murdoch administration at Sky.
This message was authored by simon194 This message was authored by: simon194
You also have to take into account that Sky most likely will not be renewing their satellite carriage agreement with SES in 2028.
