Discussion topic: SKY Q Box Connected to wall mounted face plat (Euro Module)
Message posted on 04 Jan 2026 11:06 AM
I recently upgraded my Sky HD to Sky Q.
My HD box connected to a Euro Style wall plate with two modules - one for each cable.
The engineer who upgraded advised that he couln't connect the new Q cables to the faceflate modules due to the possibility of interference. I now have a cable coming out of the wall directrly into the back of the Q box which is unsighly! Is anyone aware of this problem and of any workaround. I've looked on line and can see that there are two modlues avaialble " EuroFix 25x50mm Satellite Non- Isolated Modlue " and an Isolated Module version - would buying the correct one - Isolated / non- Isolated solve the problem, if so which one do I need.
Some futher infom - I am not connecting to a communal insolation, Just a single domestic connection.
Message posted on 04 Jan 2026 11:27 AM - last edited: 04 Jan 2026 11:33 AM
Re: SKY Q Box Connected to wall mounted face plat (Euro Module)
@MM74 This is the optimal type of media plate satellite connector, depending upon the angle between the incoming coaxial cable and the F type socket you may need to use a Right Angle F connector adaptor to prevent sharp bends in your coaxial cables.
A typical source of a suitable module; Link to typical Media Plate satellite connector
Godfrey.
Message posted on 04 Jan 2026 12:41 PM
Many thanks – that’s most useful and I think I now understand the problem – my current Euro module requires the incoming cable to be cut and physical attached to the back of the module – not dissimilar to coaxial ariel cable fitting. It appears that the picture you sent requires the incoming satellite cable to be a attached to a male connecting adaptor, which is then screwed onto the female connecter on the back of the module.
Message posted on 04 Jan 2026 12:49 PM - last edited: 04 Jan 2026 12:55 PM
@MM74 wrote:
Many thanks – that’s most useful and I think I now understand the problem – my current Euro module requires the incoming cable to be cut and physical attached to the back of the module – not dissimilar to coaxial ariel cable fitting. It appears that the picture you sent requires the incoming satellite cable to be a attached to a male connecting adaptor, F-type connecter is the screw on type, which is then screwed onto the female connecter on the back of the module.
Message posted on 04 Jan 2026 01:01 PM
BRILLIANT -thanks
