Discussion topic: No Satellite Signal
This message was authored by: Neil+and+Ellie
No Satellite Signal
Got No Satellite Signal earlier on some channels ITV 1 , Some Sky Sports, Premier Sports etc
Rebooted and that fixed it
Now every channel has gone. Have tried the fixes recommended by Sky with no success. Engineer visit booked but just wondered if anyone had any other ideas. It's extremely cold here but no snow
This message was authored by: Newts77
Re: No Satellite Signal
Hi, You sure it's bot your WiFi??
Chances are your dish is slightly out of alignment and the cold might be exacerbate it.  No amount of reboots will assist with that...
Avatar for Neil+and+Ellie
Level 6 icon
Thanks both
Internet is fine
Thought it was likely something to do with the cold as have had no issues before
Engineer is coming Monday so will live off the apps until then!
Level 6 icon
And I've just turned it on. No signal again
Tried one last reboot and lo and behold everything is back and working fine
Now not sure about the engineer visit. A bit worried that there is something underlying but what could they do if it's up and running. I do wonder about the extremely cold weather last night.
See I might have to pay a cancellation fee if £25.
@Neil+and+Ellie
I'd keep the appointment.
With a “no satellite signal” message, check that the connections from the Sky dish going into the back of your Sky Q box are still finger tight. Otherwise it’s very likely either;
▫️a dish misalignment,
▫️a failing LNB (on the arm of the dish),
▫️water getting into the cabling
It’s worth mentioning that:
🔹 a misalignment is not necessarily something that will be visible to the naked eye and could only affect one or two channels (amongst the first to be affected may be TNT or GB News),
🔹 wind, rain or snow can affect the satellite signal.
🔹a Sky Q box requires a periodic 'Keep alive' signal that is delivered via the satellite so if that isn’t received the box will close down until the satellite signal is restored.
Level 6 icon
@Daniel0210
Thanks. That's the way my thought processes were going too
Sky have confirmed that I will be charged £25 if I cancel so may as well get it checked for free
Feel a bit bad about taking an appointment that someone else could you use but better to be safe
