Discussion topic: SKY Dish moved slightly
This message was authored by: KrisColeman
My SKY dish seems to have moved slightly. The mini box is dipping out at times from the main box. I also have a small band of thin black lines appeared on the bottom of tv.
Re: SKY Dish moved slightly
@KrisColeman
If the dish has moved slightly out of alignment you'll need to call Sky and book an engineer.
▪️I AM NOT A SKY EMPLOYEE ▪️
If the channel works fine on the main box then it won't be the satellite signal.  (As the main box caches it and passes it to the mini)
Can you post a picture of these black lines?  (I presume you've tried the usual power off/on and checked seating of cables)
