Discussion topic: SET PIN message won't clear from screen preveyme watching programmes
This message was authored by: Paul09956
I've come in from work turned TV on and see SET PIN message on screen. It will not let me clear the message. The same message isn't appearing on my sky mini box. How do I clear this message? Typically there's no one I can speak to at Sky to resolve this at 6.50pm!
Re: SET PIN message won't clear from screen preveyme watching programmes
Hi @Paul09956
Have you tried rebooting your Q box?
hi @Paul09956
Is there any chance it is a message from your TV and not SKY - if so you will need tio use the TV's remote
As SKY has a PIN set by default (the default being last 4 digits of your viewing card) I do suspect it is your TV rather than SKY
