Discussion topic: Router problem
This message was authored by: Jack+Cane
Router problem
I have just obtained a new router from my isp (Zyxel)  & it says on the tv screen " it looks like you don't have an internet connection right now" tried all sorts but nothing seems to work, have been on the phone to my isp who advised contacting Sky but speaking to someone is almost impossible so I've ended up here, does anybody have any advice?
Avatar for Jack+Cane
Re: Router problem
Fixed it
Re: Router problem
@Jack+Cane wrote:
Fixed it
@Jack+Cane glad you are sorted how did you fix it so if others have the same problem they will know what to do
LG 49SJ 810 V UHD TV
Google Pixel 10 Pro XL mobile
Re: Router problem
I'm really sorry but I couldn't tell you, just messed around with it & it eventually connected, sorry I can't be of more help but I'm useless with all this technology
Re: Router problem
@Jack+Cane no worries
