This discussion topic has been answered Discussion topic: Reverting to a HD Box
Message posted on 17 Sep 2023 10:27 PM
I'm cancelling my SkyQ subscription so I need to return the Q box.
I still have an old HD box. Will this work as I had a new dish when my SkyQ was installed?
Message posted on 17 Sep 2023 10:51 PM
Only if they installed a hybrid LNB and even then, only for live broadcast free to air channels
Message posted on 19 Sep 2023 07:08 AM
Re: Reverting to a HD Box
Thanks. I've tested it and unfortunately I'm getting the "no satellite signal " message.
Message posted on 19 Sep 2023 07:35 AM
hi @Tonmawr2000
Without changing the LNB back to a 'Universal' LNB (or Hybrid) you won't be able to use the old box.
The newer 4K Freesat boxes can use the Wideband LNB that SKY Q uses so if you want Freesat this may be a better option (although note, it seems they can be a little temperamnetal to get working initally with the woideband LNBs but a discussion on here has the tips -sorry I haven't searched for it)
Message posted on 19 Sep 2023 09:17 AM - last edited: 19 Sep 2023 09:18 AM
@nigea99 wrote:
(although note, it seems they can be a little temperamnetal to get working initally with the woideband LNBs but a discussion on here has the tips -sorry I haven't searched for it)@Tonmawr2000
From memory, posts have suggested leaving the Freesat 4K box plugged into an internet connection overnight and it finds the satellite signal the next morning: presumably one or more software updates take place.
