Discussion topic: Returns
This message was authored by: James1081
Returns
Didn't receive pre paid returns box to pack up the equipment to return it
Re: Returns
@James1081  You can use your own packaging.
You can print off the labels for the returns here https://www.sky.com/help/articles/return-tv-broadband
Remember to keep your proof of posting.
Re: Returns
@James1081
If you’ve successfully cancelled your subscription Sky should send out returns packaging near the end of the cancellation period, [14 days for Broadband hub and 31 days for Sky Q box(es)], to the address that the subscription was registered at.
Note: If you’ve moved across to Sky Glass or Stream the packaging is sent out later (5-6 weeks) in case you change your mind.
