Discussion topic: Returning sky equipment
Message posted on 18 Mar 2024 01:56 PM
How come I'm having to return my sky equipment,I cancelled my subscription as I'm off work sick at the moment,when I'm back working and can afford it again I'll be going back to my old package,seems daft sending it back?
Message posted on 18 Mar 2024 02:05 PM
Re: Returning sky equipment
Cancelling the subscription does just that. As the boxes are essentially leased against an active sub, Sky can re-use your kit for someone else. If you don't contact Sky again, the kit will need to be returned as you never owned the Sky Q box.
Samsung UE49MU7070XX - Samsung MS550 Soundbar+ with 9000S Rears
Sky Q 2Tb + 3 Minis - BT Full Fibre 900
Message posted on 18 Mar 2024 02:33 PM
And when you return your Sky Q box remove and keep your viewing card because if you take out a new subscription in the future Sky will think you've kept it and won't automatically send a new one with a new box.
Message posted on 18 Mar 2024 02:37 PM
@Bazw As Sky Q is being phased out, might be worth doing some research on Sky Stream? There's an excellent journey documented here by @lettice
