Discussion topic: BT Wholehome disconnecting from Sky Q every few day
This message was authored by: HOW
I have BT wholehome , with 3 large discs araound the house. Everything has worked perfectly for around a year but now Sky is disconnecting every few days and i have to go around the house to re start everytihng. It is so frustrating. No other wifi connected device disconnect, only Sky
Re: BT Wholehome disconnecting from Sky Q every few day
Yep. Welcome to my world circa 2019. Ended up using ethernet into a disc to piggyback its wifi.
Yup, BT WH only works reliably if you connect a disc to Q box via Ethernet.  (And disable WiFi)
Avatar for HOW
Have you found an alternative booster to replace Wholehome?
No just carried on using that. Not going to change it just because Sky Q's wifi is rubbish.
