Discussion topic: Return the sky item
This message was authored by: MfonAbasi
Return the sky item
I would like to have the box so I can return sky items in my possession because I have cancelled the subscription
Re: Return the sky item
@MfonAbasi
If you’ve successfully cancelled your subscription Sky should send out returns packaging near the end of the cancellation period, [14 days for Broadband hub and 31 days for Sky Q box(es)], to the address that the subscription was registered at. If you’ve moved to Sky Glass or Stream any Sky Q packaging is sent out a bit later in case you change your mind.
You can use any packaging as long as it’s secure and you may want to put a note inside with your account number and a list of equipment that is included. This link explains about how to receive an email with your return labels through Royal Mail.
https://www.sky.com/help/articles/return-tv-broadband
If you haven’t anything suitable contact Sky again and ask if they’ll re-send. Keep your proof of posting safe and indefinitely and if you use Royal Mail’s collect from home service, keep a record of the tracking number.
