Discussion topic: Return Sky Q box
Message posted on 30 Sep 2023 12:01 PM
Return Sky Q box
I need a box from Sky to retiurn a Sky Q box
Message posted on 30 Sep 2023 12:08 PM
Re: Return Sky Q box
Hi @Rosarie47 You should find everything you need to know below.
Message posted on 30 Sep 2023 12:14 PM
@Rosarie47
If you’ve successfully cancelled your subscription Sky should send out returns packaging near the end of the cancellation period, [31 days for Sky Q box(es)], to the address that the subscription was registered at.
Note:~ If you’ve switched from Sky Q to Sky Glass the packaging is usually sent out later (at 5-6 weeks) in case you change your mind about Glass.
You can use any packaging as long as it’s secure and you may want to put a note inside with your account number and a list of equipment that is included. This link explains about how to receive an email with your return labels through Royal Mail.
https://www.sky.com/help/articles/return-tv-broadband
If you haven’t anything suitable contact Sky again and ask if they’ll re-send. Keep your proof of posting safe and indefinitely and if you use Royal Mail’s collect from home service, keep a record of the tracking number.
