2
This discussion topic has been answered Discussion topic: Replacement viewing card
This message was authored by: SajAli71
Does anybody have a link for ordering a replacement viewing card please? We had our Sky Q box changed and left our viewing card in it 😔
This message was authored by: SKY1992bf Answer
Re: Replacement viewing card
@SajAli71  You would need to call sky to request a replacement
Your not talking directly with Sky this is a customer helps customer forum only with no account access
Click on the need more help drop down at the very bottom of the link below to reveal an 0333 number if your in uk (full numbers aren’t permitted on the forum)
If in ROI using the same link change the flag in bottom right hand corner and refresh the link before following above instructions to reveal an 0818 number
https://www.sky.com/help/home#M1014
or if you have sky mobile/talk call 150 Calls to Sky Customer Services from your Sky Talk landline phone or a Sky mobile are free
The start will be automated which may try to send you here to the forum or suggest you receiving a text. Stay on the line as long as possible and don’t hang up. If necessary say nothing when the automated system asks you what your call is about as it should then route your call into a queue for the next available agent.
Avatar for SajAli71
Thanks.  I have called them but was just wondering whether there was an online option.
