Discussion topic: Replacement Sky Q box
Message posted on 18 Nov 2024 06:32 PM
My Q box is not fast forwarding without jumping back and it takes a while when I press for a channel to come on
Message posted on 18 Nov 2024 06:48 PM
Re: Replacement Sky Q box
Hi @Chr12
