Discussion topic: Replacement Sky Q Mini box
This message was authored by: garydavid
Hi I need a replacement Sky Q mini box. I can only see sky Q box replacement any advice.
Re: Replacement Sky Q Mini box
@garydavid
What's the issue with the mini box that makes you believe it needs replacing?
Avatar for garydavid
Hi it just keeps turning off by itself very intermittent
@garydavid
If you haven't tried it already reboot your router by switching it off for a minute. Once that's up and running again reboot the main Sky Q box, then the same with any mini boxes if necessary-
~ press the 🏠 button
If the above does not work and you still getting problems, you can replace a faulty mini box online via the  link on section 2;
Sky Q box won't turn on or is stuck on standby | Sky Help | Sky.com
Thanks for all your help guys I've ordered a replacement. Not sure if there is a charge or not but thank you 👍
@garydavid
There isn't a charge for swapping a faulty box.
