Discussion topic: Replacement Q box: No Apps?
This message was authored by: mccormack
Hi All
Got a replacement Sky Q box and the usual Apps of Netflix/iPlayer, etc are not showing. Do I need to wait a bit (intalled 20 minutes ago?)
Re: Replacement Q box: No Apps?
@mccormack wrote:
Hi All
hi @mccormack
Chances are that the software & apps are not fully up to date :
To check & refresh if needed follow all the steps on this link (skipping any that are OK):
https://www.sky.com/help/articles/apps-on-sky-q-and-glass-basic-checks
Please note that the step to refresh apps often does not action immediately and may take several hours before it does
Avatar for mccormack
Cheers! I thought I was losing my mind there.....
