Discussion topic: Replacement Dish
This message was authored by: Phil+Stone
Replacement Dish
I need a replacement satellite dish as mine has rusted thru
Re: Replacement Dish
@Phil+Stone  Unless your Satellite reception is affected Sky won't routinely replace the dish as it is your dish, you own it.
Avatar for Phil+Stone
Can I pay to have it replaced? If so, how much?
This message was authored by: Padam_Padam
If your present dish is affecting signal quality then it should be replaced free of charge.
Hi @Phil+Stone   You will need to ask Sky. The chances are they will replace it free.
You can choose to pay a local independent installer if you wish: they'll charge parts and labour, including reorientating the dish.
