Discussion topic: Renote control
This message was authored by: Stuart2810711
Renote control
I have got sky q and a mini box
If I watch my recordings on either
Sky q box or mini box if I press the back button to finish and go back to the main menu there is a delay in going back to the main menu is  very irritating
Can anybody help
Re: Renote control
@Stuart2810711
Try a reboot of the main Sky Q box, then once that’s back up and running do the same with any mini boxes if applicable -
~ press the 🏠 button
Allow 5-10 minutes before things hopefully revert back to normal.
Avatar for Stuart2810711
Re: Renote control
Ok thanks will try
