Discussion topic: Sky q box appears to be on and HDMI cables connected however no picture
Message posted on 06 Jan 2025 08:53 PM
Have disconnected and reconnected power cable plus have unplugged and repuggled hdmi cable at TV & Sky q ends
Message posted on 06 Jan 2025 08:55 PM
							Re: Sky q box appears to be on and HDMI cables connected however no picture
Hi @Thunder63
First make sure that the Television is switched on and is switched to the HDMI input to which the Q box is connected.
Then with the Q box switched on with green led illuminated
Press
Home 1 0 8 0 Home
on the Q box remote control.
This will change the Q box to standard resolution which will work for all TV’s.
Message posted on 06 Jan 2025 09:14 PM
Can't get any response when pressing Home 1080 Home
when I take out the orange power cable and replace I get the message on the TV
Sky TV you will be ready to go in a couple of mins
followed by press the home button when the screen goes blank
then it goes HDMI 1 no signal
Message posted on 06 Jan 2025 09:17 PM
When I remove & replace the orange power cable sometimes I don't get any messaged on the screen !
Message posted on 06 Jan 2025 09:30 PM
Light on box goes from red to yellow doesn't go green?
Message posted on 06 Jan 2025 09:33 PM
@Thunder63 wrote:
Can't get any response when pressing Home 1080 Home ..........
Was the Qbox on with green led @Thunder63
Message posted on 06 Jan 2025 09:42 PM
When I pull out the power cable I get the blue Q light come on followed by the messages mentioned previously the light goes from red to yellow..no green light comes on?
Message posted on 06 Jan 2025 09:44 PM
How do I get the green light to come on?
Message posted on 06 Jan 2025 09:48 PM
hi @Thunder63
Have you tried pressing the Standby button (Amber led) on the front of the Q box.
If this turns the Q box on
Then make sure that you are pointing your remote at the Q box and press 1 & 3 together until the led flashes and follow onscreen instructions to re- pair to TV.
Message posted on 06 Jan 2025 09:52 PM
Re your message 'This will change the Q box to standard resolution which will work for all TV’s.'
We haven't changed our Tv?
Has something changed at Skys end?
Message posted on 06 Jan 2025 09:56 PM
The remote seems to working.. it beeps when. I press the button in the middle of the sky q box?
Message posted on 06 Jan 2025 09:57 PM
No Nothing has changed @Thunder63
It's just that 1080i resolution is the native Q box resolution
Message posted on 06 Jan 2025 10:00 PM
Yes have tried pressing the Standby button (Amber led) on the front of the Q box however it doesn't turn on
Message posted on 06 Jan 2025 10:02 PM
why the issue if nothing has changed?
Message posted on 06 Jan 2025 10:07 PM
The issue is getting the green light to come on?
