Discussion topic: Remove Channels (not from guide or contract)
Message posted on 08 Jun 2025 02:06 PM
I've a new SKY Q box, and was wondering if it would be possible to remove channels from use of the up/down buttons.
I don't want to remove them from the guide, I've done that in favourites.
I don't want to remove them from my contract because I'm on a basic plan.
I want to remove all the channels I never watch when I'm using the up/down buttons on the remote.
For example, I never watch channel 100, but I do watch channels 99 and 101. When I'm using the remote up/down buttons, I want to go directly from 99 to 101, bypassing 100.
Thanks.
Message posted on 08 Jun 2025 02:09 PM
Re: Remove Channels (not from guide or contract)
No, that's not possible. Strangely enough, Sky would prefer to advertise what's available through increasing the subscription.
Message posted on 08 Jun 2025 02:40 PM
Your post has me somewhat confused. On Sky Q there isn't a channel 100 in the epg. The favourites run from 1 to 99 then the proper epg starts at 101 which is BBC One. Not sure if it's different if you're in the ROI though.
Message posted on 08 Jun 2025 02:44 PM
Thanks.
hi @liz1935
Do you have more than 90+ favourites ?
If you select your channels by using their favourite number then the up/ down arrows will take you between them just like thay are together in the Guide
