4
This discussion topic has been answered Discussion topic: Remote
This message was authored by: JHaystead
Remote
Just had a cupboard fitted as part of a media wall and the sky Q box now lives in there. The remote does not work through the cupboard. Just wondering if the new voice activated remote will being as it is Bluetooth and not IR. Can anyone help please.
Re: Remote
Hi @JHaystead
Yes any Q Bluetooth remote with voice control will work the Q box through a cupboard.
Main concern is to ensure adequate ventilation for the Q box if totally enclosed
Re: Remote
Hi @JHaystead
Avatar for JHaystead
Re: Remote
@oldfella @Thank you. Very quick responding as well. 🙏🏻🙏🏻
This message was authored by: WillinLeeds
Re: Remote
Can someone advise how we can connect this please. The ventilation is fine
Re: Remote
hi @WillinLeeds
To pair any remote with the box they must have line of sight for the pariing process as they use Infrared until paired
If you need to reset  a remote to re-pair then:
Press & Hold the 7 & 9 until the remote's light (red LED above the SKY logo button) flashes 4 times
Then press 1 & 3 together to go through to re-pair with the box and your TV - make sure it has line of sight of the box as until it is paired it uses Infrared (as mentioned above)
https://www.sky.com/help/diagnostics/sky-q-remotes/setting-up-remote
