Discussion topic: No picture on certain channels - think related to parental PIN
This message was authored by: ClaireSKYbox
My wife said our Sky mini box doesn't work at all on various channels - it just has a blank screen with no message.  Those channels all worked on the main Q box and work on my Sky Go App
Seemed odd and having just played around with the boxes, it looks like the channels not working on the mini box are those that are showing something which is pin protected.  The main Q box asks me for the password and i enter it but just blank on the Sky Mini box.  I wondered if i might be able to fix it when i go into parental settings on the Mini box, but i can't get into it - i enter our PIN and it just freezes there and nothing happens
It made me also wonder that there are some things i try to download and it is telling me i have to upgrade my subscription (not true as i have everything and it works on Sky Go) -  I hadn't thought to do so but just checked ont he main box and that program downloads fine on there.  Multiple other programs download too so it is strange
We have reset the box multiple times so it isn't that
Has anyone come across this before?
Nick
Re: No picture on certain channels - think related to parental PIN
Nick
Hi @ClaireSKYbox
I suspect it is just a case of poor WiFi connectivity with the mini.
It's not going to be connected with pin input and if you have a blank screen then the channel has not been reached and pin protection would not be requested.
Reboot the mini as above.
