Discussion topic: Remote
This message was authored by: Harleysm
Remote
Every time I put the box on and press the remote nothing happens apart from the box turning of when a button is pressed I've tried to change the batteries and nothing else happens any one know what I can do?
Re: Remote
Hi @Harleysm
First try rebooting your Q box.
Then if you still have an issue
Try completly resetting your Bluetooth remote.
Then make sure that you are pointing your remote at the Q box and press 1 & 3 together until the led flashes and follow onscreen instructions to re- pair.
