Discussion topic: Remote won’t pair with tv
This message was authored by: Tr2204
My remote will no longer pair with my tv although it had previously
This message was authored by: xchrissyboix23
Re: Remote won’t pair with tv
Hello
if you press the home button on your remote which looks like a house and go down to settings, once in settings go to setup then go down to remote control, choose your remote, then follow the instructions provided and you should be able to pair your remote to your tv again hope this helps
Please Note: I am just another customer not an employee
Sky Glass Gen 2 43” Volcanic Grey, Sky Live, x1 Sky Stream Puck, Sky Broadband Superfast (Part Fibre), Sky Max Hub (SR213), Sky Ultimate TV, Sky Cinema, Sky UHD & Dolby Atmos, Whole Home, Ad Skipping. Former Sky Q Customer
@Tr2204 Try resetting your remote.
Press the buttons 7 & 9 together on the remote until it’s led flashes four times.
Then press 1 & 3 together until the led flashes twice then follow onscreen instructions to repair the remote.
LG 49SJ 810 V UHD TV
Google Pixel 10 Pro XL mobile
