Discussion topic: Remote won’t connect to tv
This message was authored by: TomJackson
Pressed 7&9 and 1&3 try everything I can and won't connect
Re: Remote won’t connect to tv
Hi @TomJackson
@oldfella wrote:
Hi @TomJackson
@TomJackson if @oldfella suggestion doesn't work try  rebooting your main Q box first ie
then
Try resetting your remote.
Press the buttons 7 & 9 together on the remote until it’s led flashes four times.
Then press 1 & 3 together until the led flashes twice then follow onscreen instructions to repair the remote.
LG 49SJ 810 V UHD TV
Google Pixel 10 Pro XL mobile
