Discussion topic: Remote will not work have got a remote from different room that does work
This message was authored by: Howard987
Message posted on 27 Mar 2026 03:19 PM
Remote will not work have got a Remote from different room that does work
Find out more
Message posted on 27 Mar 2026 03:24 PM
Re: Remote will not work have got a remote from different room that does work
hi @Howard987
May I suggest you try a reset of your remote:
Press & Hold the 7 & 9 until the remote's light (red LED above the SKY logo button) flashes 4 times
Then press 1 & 3 together to go through to re-pair with the box and your TV - make sure it has line of sight of the box as until it is paired it uses Infrared
https://www.sky.com/help/diagnostics/sky-q-remotes/setting-up-remote
