Discussion topic: Remote replacement
This message was authored by: Trusse03
Remote replacement
Our old remote broke, we've received a new remote from sky, but it won't connect to our sky box, we've done what it says in holding 1 and 3 till the red lights flash on the sky remote, I've even tried doing 7 and 9 to reset to factory settings then 1 and 3 again.
Online tutorials say we have to disconnect the old remote, but we can't do this as its broken.
Any suggestions?
Re: Remote replacement
Any suggestions?
Hi @Trusse03
You do not need to disconnect the old remote.
Pairing a new one will automatically replace it.
Try completly resetting your new Bluetooth remote.
Avatar for Trusse03
I've tried all this, it just doesn't connect to our sky q box.
hi @Trusse03
Reboot the Q box and then try resetting the remote again when the box is up and running.
Reset your Bluetooth remote again.
Avatar for Trusse03
Tried this as well, that didn't work,
Avatar for Trusse03
So spoke to a sky customer advisor on phone other say, and he suggested all the same steps even though I'd already done them all.
Nothing worked, so he sent out a replacement remote, and again it won't connect to our sky q box
Is the IR sensor on the box in clear line of sight?
This message was authored by: alistair1951
Did you put batteries in?
