Discussion topic: Remote problem
Message posted on 09 Aug 2026 01:26 PM
Remote problem
I can't get my sky remote to work on my sky multiroom box, I've changed the batteries and the led light works and it turns up the tv but I won't let me do anything else connected to the sky box
Message posted on 09 Aug 2026 01:54 PM
Re: Remote problem
Hi @Kirsty242
With the mini box on with green led try completly resetting your Bluetooth remote.
Then make sure that you are pointing your remote at the mini box and press 1 & 3 together until the remote led flashes and follow onscreen instructions to re- pair.
