4
This discussion topic has been answered Discussion topic: Remote problem
This message was authored by: alienmitch2529
Remote problem
2 Remotes just studdenly stopped working!
My sky Q swipe touch and the other, one of my sky extra boxes controllers can't use volume up! Can't go up! Also not turning tv on or off.
Tried changing batteries
Syncing again
Still nothing!
Sky bot no help at all!
Calling sky tomorrow as got remote insurance!
M Davin
Re: Remote problem
@alienmitch2529
Unusual to have problems with two remotes simultaneously but if they are definitely broken/faulty, if you follow this link it should allow you to do some troubleshooting and then it’ll send you to a form to request a replacement (this is not available for ROI customers).
https://www.sky.com/help/articles/lost-stolen-damaged-sky-q-equipment#get-in-touch
I'm not sure if it will allow you to order twice.
Re: Remote problem
@alienmitch2529
Avatar for alienmitch2529
Level 2 icon
Re: Remote problem
Hi, thank you for reply! My problem solved this morning. I called sky after more attempts Syncing again, still nothing from either controller, on both sky + controller extra box and the Sky Q swipe on sky Q box. So now two replacement controllers on there way.
M Davin
Re: Remote problem
@alienmitch2529 just be aware when they arrive you won't get another Q swipe remote as you call it as they have been discontinueed
LG 49SJ 810 V UHD TV
Google Pixel 10 Pro XL mobile
Level 2 icon
Re: Remote problem
Sky insurance replacing both controllers.
Got main sky Q box and 3 mini boxes in 2016, so had a good 6yrs  controllers working.
Insurance explained they discontinued, told them I'm not bothered if new main controller not swipe as long as it works. Spent more time having to reset swipe controller over the years, they more hassle than button controllers.
M Davin
