Discussion topic: Remote only working when sky box is on show
Message posted on 17 Aug 2025 10:19 AM
Our sky box is in the cubby and the remote will not work unless the door is open? Any ideas to why?
Message posted on 17 Aug 2025 10:21 AM
Re: Remote only working when sky box is on show
Looks like it's lost it's Bluetooth connection @Rhiannon34
It needs full line of sight to re pair
