Discussion topic: Remote not working
Message posted on 07 Nov 2023 09:11 PM
Remote not working
Remote control is being intermittent with working, changed batteries and made no difference
Message posted on 07 Nov 2023 09:14 PM
Re: Remote not working
Hi @Jamesjc92
Try completly resetting your Bluetooth remote.
Failing this
Check the following link and it will lead to a form for a replacement remote.
https://www.sky.com/help/articles/lost-stolen-damaged-sky-q-equipment
@Jamesjc92
After checking the basics, ie; fresh batteries, re-pairing etc if your Sky Q remote is definitely broken/faulty, if you follow this link it should allow you to do some more troubleshooting and then it’ll send you to a form to request a replacement (apparently this is not available to customers in the ROI).
https://www.sky.com/help/articles/lost-stolen-damaged-sky-q-equipment#get-in-touch
(It might be quicker to purchase a new one from a retailer / main supermarket. If you do that as well you’ll always have a spare).
HAPPY NEW YEAR
