Discussion topic: Remote not selecting channels
Message posted on 16 Sep 2024 01:13 PM
Hi my sky remote is not allowing me to scroll and select the channel I want since today am
Message posted on 16 Sep 2024 04:15 PM
Re: Remote not selecting channels
@Theowarda Have you tried rebooting your Q box ie
then
Try resetting your remote.
Press the buttons 7 & 9 together on the remote until it’s led flashes four times.
Then press 1 & 3 together until the led flashes twice then follow onscreen instructions to repair the remote.
LG 49SJ 810 V UHD TV
Google Pixel 10 Pro XL mobile
