Discussion topic: Remote not connecting
Message posted on 10 Aug 2023 09:03 PM
Dog chewed the old tv remote. New remote won't connect. I've tried 7 & 9 on the new remote and then 1 & 3 and the remote flashe but the tv doesn't respond (tv turned on and sky is on the screen)
Message posted on 10 Aug 2023 09:13 PM
Re: Remote not connecting
Hi @CS
Try first rebooting your Q box.
Then with the Q box on,
Try completly resetting your Bluetooth remote again.
Then make sure that you are pointing your remote at the Q box and press 1 & 3 together until the led flashes and follow onscreen instructions to re- pair.
