12
This discussion topic has been answered Discussion topic: Remote issue
This message was authored by: DJGA
Remote issue
Reset sky mini box
turns on and off ok
when I turn it on the Home Screen is showing on screen
got three remotes, one new, and when I press 1 and 3 on any of the remotes, they flash 20 times instead of 2
please help
Avatar for DJGA
This message was authored by: DJGA Answer
Re: Remote issue
Sky reprogrammed my three remotes for me
Re: Remote issue
@DJGA wrote:
Reset sky mini box
turns on and off ok
please help
Hi @DJGA
With the mini on
Try completly resetting your Bluetooth remote.
Then make sure that you are pointing your remote at the Q box and press 1 & 3 together until the led flashes and follow onscreen instructions to re- pair.
Re: Remote issue
edited  as it was a duplicate of what @oldfella posted
Avatar for DJGA
Re: Remote issue
Tried 6 and 9 in sight of box
nothing I'm afraid must be the box?
Avatar for DJGA
Re: Remote issue
Tried that, 7 and 9 flash 4 times
4 and 6 flash 4 times
1 and 3 flash 20 times on all 3 remotes
Re: Remote issue
6 and 9 does nothing @DJGA
First reboot the mini.
To reboot press Standby on your minii remote (if the box responds to the remote), and then switch off and unplug at the mains.
Wait at least 30 secs and then Plug back in and switch your mini box back on at the mains.
Wait for the on screen instructions to disappear and the front led to turn Amber. Then wait for 30 secs before you press Home on your mini remote or if this is not working press the standby button on the front of the mini box (Amber led)
Then with the mini on the Home Screen,
Completly reset your Bluetooth remote.
Avatar for DJGA
Re: Remote issue
Hi
done a reboot three times now
still the same problem
Avatar for DJGA
Re: Remote issue
You say point the remote at the Q box, is that not the mini box? As the mini box is the problem
Re: Remote issue
Yes @DJGA
A mini is also a Q box.
Avatar for DJGA
Re: Remote issue
Thanks for help 👍
Avatar for DJGA
Re: Remote issue
Got sky coming to my house now thanks for all your help
This message was authored by: Harpreet05
Re: Remote issue
Any idea how this issue was resolved by Sky?
Avatar for DJGA
Re: Remote issue
