This discussion topic has been answered Discussion topic: Remote issue
Message posted on 06 Aug 2023 10:13 PM
Reset sky mini box
turns on and off ok
when I turn it on the Home Screen is showing on screen
got three remotes, one new, and when I press 1 and 3 on any of the remotes, they flash 20 times instead of 2
please help
Message posted on 25 Oct 2023 03:28 PM
Sky reprogrammed my three remotes for me
Message posted on 06 Aug 2023 10:18 PM
							Re: Remote issue
@DJGA wrote:
Reset sky mini box
turns on and off ok
please help
Hi @DJGA
With the mini on
Try completly resetting your Bluetooth remote.
Then make sure that you are pointing your remote at the Q box and press 1 & 3 together until the led flashes and follow onscreen instructions to re- pair.
Message posted on 06 Aug 2023 10:18 PM - last edited: 06 Aug 2023 10:19 PM
							Re: Remote issue
edited as it was a duplicate of what @oldfella posted
Message posted on 06 Aug 2023 10:21 PM
							Re: Remote issue
Tried 6 and 9 in sight of box
nothing I'm afraid must be the box?
Message posted on 06 Aug 2023 10:23 PM
							Re: Remote issue
Tried that, 7 and 9 flash 4 times
4 and 6 flash 4 times
1 and 3 flash 20 times on all 3 remotes
Message posted on 06 Aug 2023 10:32 PM
							Re: Remote issue
6 and 9 does nothing @DJGA
First reboot the mini.
To reboot press Standby on your minii remote (if the box responds to the remote), and then switch off and unplug at the mains.
Wait at least 30 secs and then Plug back in and switch your mini box back on at the mains.
Wait for the on screen instructions to disappear and the front led to turn Amber. Then wait for 30 secs before you press Home on your mini remote or if this is not working press the standby button on the front of the mini box (Amber led)
Then with the mini on the Home Screen,
Completly reset your Bluetooth remote.
Message posted on 06 Aug 2023 10:35 PM
							Re: Remote issue
Hi
done a reboot three times now
still the same problem
Message posted on 06 Aug 2023 10:39 PM
							Re: Remote issue
You say point the remote at the Q box, is that not the mini box? As the mini box is the problem
Message posted on 07 Aug 2023 10:06 AM
							Re: Remote issue
Message posted on 07 Aug 2023 10:10 AM
							Re: Remote issue
Thanks for help 👍
Message posted on 08 Aug 2023 06:37 AM
							Re: Remote issue
Got sky coming to my house now thanks for all your help
Message posted on 25 Oct 2023 02:32 PM
							Re: Remote issue
Any idea how this issue was resolved by Sky?
