Discussion topic: Remote controls
Message posted on 19 Sep 2024 09:25 PM
Remote controls
Our sky Q control won't work, we have tried battery and turn off and on and tried resetting but nothing
Message posted on 19 Sep 2024 09:28 PM
Re: Remote controls
First reboot your Q box.
Have you tried rebooting your Q box?
Then with the Q box on with green led try completly resetting your Bluetooth remote.
Failing this
Check the following link and it will lead to a form for a replacement remote.
https://www.sky.com/help/articles/lost-stolen-damaged-sky-q-equipment
In the meantime if you have an Apple device with Sky Go you can set up a virtual remote to control your Q boxes.
See following link.
https://helpforum.sky.com/t5/Sky-TV/Virtual-Sky-Q-Remote-Now-Available-on-Sky-Go/ba-p/4363637?
Message posted on 19 Sep 2024 09:33 PM
Re: Remote controls
Aw thank you I will give all this a go now.
