Discussion topic: Remote control
Message posted on 20 Jul 2025 03:20 PM
Remote control
How do I connect my remote control to sky a box so it can also control the tv
Message posted on 20 Jul 2025 03:28 PM
Re: Remote control
This is done by pressing & holding 1 & 3 together (although I think you can just go Home - Settings - Setup - Remote Control)
although may I suggest you try a reset of your remote first:
Press & Hold the 7 & 9 until the remote's light (red LED above the SKY logo button) flashes 4 times
Then press 1 & 3 together (as above) to go through to re-pair with the box and your TV - make sure it has line of sight of the box as until it is paired it uses Infrared
https://www.sky.com/help/diagnostics/sky-q-remotes/setting-up-remote
