Discussion topic: New sky q mini box has messed up whole system
This message was authored by: rozs
Hi
Purchased an additional sky q  mini box went to install yesterday.  I have connected ones before with no issues.
It wouldn't connect to main box. Now all the additional mini boxes 2 others now won't connect.
Main sky q box .... against the watch on additional sky mini boxes has a X against it . It won't reactivate . Tried everything yesterday and called tech help,  after 1 hrs on the phone and going around in circles we are no further on. (Just did everything I did 4 more times)  Sending an engineer out on Wednesday.
Just wondering if a full reset on the main sky q box is worth a try?
Re: New sky q mini box has messed up whole system
@rozs
Where did you acquire this mini box from? And you didn't purchase (buy) it.
NOTE: I only provide help on the forum boards and NOT via Direct Messaging so DMs are switched off
Avatar for rozs
Direct from Sky.... purchased correctly.
Avatar for rozs
I know i Didn't buy it.... ok then rented from Sky. But I did pay £50 for it so did pay a purchase price as such....
That's basically just a delivery fee but yeah, pedantry - just some people buy hookey boxes and think they own them.
I would do a network reset at least on the Q with all boxes powered down and then re-do the connection one at a time.
They will form a mesh and dynamicallt choose which box is in charge of the internet connection. It's not the most stable system ever.
Avatar for rozs
Thanks.
I've tried all that yesterday,  just wondered if a full factory reset would be worth a try. We cannot get the boxes to connect to the Q. It just continues to have a  X against the mini box option on settings.
When you do a full reset on the mini it should do the "step 1 to 4" thing from the start, no reactivation through the menu. Is it doing (or attempting to do) that?
