Discussion topic: Remote control
Message posted on 16 Mar 2023 06:05 PM
Remote control
My remote control is not working. I can't change channels more then few weeks I really need help
Message posted on 16 Mar 2023 06:06 PM
Re: Remote control
Hi @Havvis
Try completly resetting your Bluetooth remote.
Then make sure that you are pointing your remote at the Q box and press 1 & 3 together until the led flashes and follow onscreen instructions to re- pair.
Message posted on 16 Mar 2023 10:28 PM
Re: Remote control
Thanks so much it's done
