Discussion topic: Remote control not working. No red light
This message was authored by: Lauren12341234
Remote not working have changed batteries and there is no red lights
its only about 6 weeks old
Re: Remote control not working. No red light
Hi @Lauren12341234
Only the Question mark button and the Microphone button will illuminate the red led on the remote.
Try completly resetting your Bluetooth remote.
Then make sure that you are pointing your remote at the Q box and press 1 & 3 together until the led flashes and follow onscreen instructions to re- pair.
Avatar for Lauren12341234
Hi
have just tried this and nothing has happened still
