Discussion topic: Remote and SkyQ not working
Message posted on 12 Sep 2024 07:50 AM
My remote won't work. Changed the battery, tried 4&6,7&9,1&3. Tried to unplug it all. Tried to reset it etc.
Stuck on accessibility screen and cannot get off at all. PLEASE HELP
Message posted on 12 Sep 2024 07:53 AM - last edited: 12 Sep 2024 07:53 AM
Re: Remote and SkyQ not working
Sky have suggested the following...
- Unpair their Sky Q remote from the box by holding 4&6
- Wait for the remote to flash
- Then dismiss the information screen "Skip & set up later"
- Hold 1&3 to repair the remote control
If 4&6 does not allow you to clear the information screen, try holding 7&9 to reset the Sky Q remote then hold 1&3 and follow the on-screen setup journey to allow the remote to control the TV.
Message posted on 12 Sep 2024 07:54 AM
Tried this! Doesn't work:(
Message posted on 12 Sep 2024 08:18 AM
Probably need a new remote then
