Discussion topic: Remote Record
This message was authored by: FIL77
Remote Record
Hi,
I've recently upgraded to Sky Q from the old Sky+HD system.
I'm no longer able to set a remote record when out and about, at work etc.
The old system had to have the viewing card number paired up to the app. Is that still the case ?
Re: Remote Record
@FIL77 wrote:
Hi,
You should still be able to set remote recordings using the Sky Go app.
Re: Remote Record
Hi @FIL77  Sky Go, important step, make sure that you connect to the Sky Q box first while still on the same network. After that, you should be able to set recordings remotely.
