3
This discussion topic has been answered Discussion topic: Reducing multi room
This message was authored by: 1873dave
Reducing multi room
I've moved house and now only need 1 sky mini box instead of 2. How do I send 1 back and change my subscription to 1 mini box on multi room?
This message was authored by: PandJ2020 Answer
Re: Reducing multi room
There is no difference in subscription cost for 1 or 2 mini boxes.
Simplest solution is to store the additional mini box until such time you completely cancel your subscription and have to return the hardware.
In theory, you could return 1 mini box now but I think safer to store it.
Hi @1873dave   I agree, if you return a Mini box then the chances are you will confuse Sky and end up with your Multiscreen subscription being cancelled.
hi @1873dave
As the others have said, it is best to keep the box until you cancel your multiroom (or full) subscription
SKY's systems aren't geared up around sending a single mini box when customers still have a multiroom subscription.
