Discussion topic: Reduce my package
Message posted on 18 Jul 2023 07:48 PM
Reduce my package
How do I reduce my package? Can I do that on my app? I'm paying for packages I don't want.
Message posted on 18 Jul 2023 07:49 PM
Re: Reduce my package
@Ollytracey You will need to call Sky or use the following link https://www.sky.com/help/articles/cancel-sky-tv#contact-leave
On the link provided (In the UK) it should include a Message Us option between 0900-1930.
You can also call on 150 from a Sky Mobile or Sky Talk line
(UK) https://www.sky.com/help/home Scroll down and click on ‘Need more help’ and it provides a 0333 number
(ROI) on the same link change the flag in the very bottom corner to the ROI flag to obtain an 0818 number.
Stay on the line and don’t hang up if prompted to. Apparently the quieter times to ring are just after 7am or about 9pm.
If you don't see the Contact options on the link above make sure java script is enabled on your browser.
