Discussion topic: The tv guide isn’t working it just says waiting for schedule and has been for 3 days now!
Message posted on 18 Jul 2023 07:19 PM
For three days all we can get is a message saying waiting for schedule and a spinner. We've tried turning the boxes off and on again tried re syncing it to the wifi but nothing is working. It is happening on the main box and the mini box
Message posted on 18 Jul 2023 07:22 PM
Re: The tv guide isn’t working it just says waiting for schedule and has been for 3 days now!
Hi @Debzyme
Try a Reset Settings in the main Q box hidden menu.
If the reset settings fixes the main Q box then try rebooting the mini again.
