Discussion topic: Red light on Sky Q box permanently on
Message posted on 19 Dec 2025 08:35 AM
The red recording light on my Sky Q box is permanently on, but I'm not recording.
Also, I lose satellite signal regularly, this is cured by rebooting the system, so there can't be a problem with my dish, or is there.
Message posted on 19 Dec 2025 08:42 AM
Re: Red light on Sky Q box permanently on
I have checked and I'm not downloading anything, so nothing "stuck".
Message posted on 19 Dec 2025 11:07 AM
Hi @JE21
