Discussion topic: Red button
This message was authored by: Pinny
Red button
Why does football on the red button keep freezing
Re: Red button
hi @Pinny
Do you have any problems when using the other apps like Netflix or Disney +?
Is it just tonight's game or all on the red button ?
Which box do you have ?
If it is 32Cxxx then you have an older 1TB non-UHD Box
If it is 32B0xxx then you have a (V1) UHD but non HDR 2TB Box
If it is 32B1xxx then you have a (V2) UHD HDR 2TB Box (which has a separate Power supply)
If it is 32B2xxx then you have a (V3) UHD HDR 1TB or 2TB Box
