6
This discussion topic has been answered Discussion topic: Recordings
This message was authored by: Manoj9
Recordings
I had a replacement Sky Q box delivered yesterday as the old one was plying up.
is there any way i can retrieve my recordings from my old box?
This message was authored by: Laing1 Answer
Re: Recordings
@Manoj9 Afraid not the recordings were stored on the hard drive if the box that was faulty.
LG 49SJ 810 V UHD TV
Google Pixel 10 Pro XL mobile
Re: Recordings
Re: Recordings
You can only re-download Sky Store content you bought.
Avatar for Manoj9
Re: Recordings
Thank you
Avatar for Manoj9
Re: Recordings
they dont give enough time to downlond the recordings elsewhere as i reported the problem on Friday evening and the new box turned up on saturday and i had to gve the old box to the driver at the same time.
My son had bought movies as well that were were stored in the old box
Re: Recordings
Hi @Manoj9   I am not sure how you expected to download the recording elsewhere, they will be copy protected (HDCP). As already stated, you can recover bought movies (Sky Store) from Purchases in the menu.
Avatar for Manoj9
Re: Recordings
Hi
thanks fo this, i shall try to get the purchased products back in that case
