This discussion topic has been answered Discussion topic: Recordings
Message posted on 31 May 2023 08:54 PM
The last few days my sky q box has been recording my programmes like it should but when I try to play the recordings it just goes to a black screen with the message at the top telling me their has been a fault with this recording and my sky go won't work either. What can I do
Message posted on 31 May 2023 08:56 PM
Hi @NShaw
Hi @NShaw
Message posted on 01 Jun 2023 10:28 PM
Re: Recordings
Thank you that did the trick and fixed the problem. Many Thanks
